Hello Guest it is November 17, 2026, 11:50:54 AM
Author Topic: Homing with the ncPod  (Read 60856 times)
Offline Greolt
  •  956 956
« on: February 02, 2007, 08:51:46 PM »
I have noticed that when slaving A with X that all settings for A become redundant and it just follows X. (as it should most of the time)
Even reversing the direction of A in "homing and limits" does not work while slaved to X.
I had to reverse wires on A to get  one motor to run LH and one RH.
So my question is will Mach's homing strategy work where using two homing switches will "square the gantry" ?
Or will the Pod not be able to differentiate between the two axis ?
See section 4.6.6 paragraph 5 of the Mach Mill user guide if you don't know what I'm on about.  ;D
Offline rcrabb
  •  146 146
Re: Homing with the ncPod
« Reply #1 on: February 03, 2007, 10:06:37 AM »
Did you try to test home yet, with switches on A and X?
Ryan
Offline Greolt
  •  956 956
« Reply #2 on: February 03, 2007, 02:06:07 PM »
Ryan
No the machine I am hoping to use the Pod on is not quite finnished.  :)  Almost but no switches yet.
If the Pod won't do this dual switch homing strategy, that will be a ball breaker for me and I will have to revert to LPT   :(
Just now I am getting all the wiring, cable management and electronics enclosure together, so hence my desire to know about the Pod.
Greg
Offline rcrabb
  •  146 146
« Reply #3 on: February 03, 2007, 02:14:39 PM »
Since I have a working machine, I'll do the test for you. I'll slave A and X and test homing. Cross your fingers. ;D
Ryan
Offline rcrabb
  •  146 146
« Reply #4 on: February 03, 2007, 03:20:57 PM »
While A is slaved to X, I can't get A to move during a home. Moves fine jogging but no movement for home. I'll try more tonight.
Ryan
« Reply #5 on: February 03, 2007, 07:25:16 PM »
Ryan,
   Are your motor settings for X and A identical? I think they will have to be.
Offline Greolt
  •  956 956
« Reply #6 on: February 03, 2007, 08:19:00 PM »
That may well be right Brett.
But my tinkering so far indicates that once A is slaved to X then A settings are ignored and X setting are used for both.
And I may well be proven wrong here.   ;D
That was what prompted my concern about whether dual driver axis slaving would work.
Greg
« Reply #7 on: February 03, 2007, 08:31:12 PM »
I'm not sure Greg, I have no pod to play with.  ;D
Thought it may be worth a try.
Offline Greolt
  •  956 956
« Reply #8 on: February 10, 2007, 10:41:47 PM »
Well it is getting to crunch time for me.  I really need to know if dual drive homing is going to work.
Presently wiring everything in to my enclosure and need to know whether it is the Pod or an LPT breakout board going in there.
Bench testing sees that homing pins do not activate the leds on the diagnostics page.
I suspect that there are some things that the Pod wants to do itself that are normaly done within Mach and it is always
going to be a compromise to get Mach to run it.  Really hope I am wrong here.
Any guidance from the gurus ?   ;D
Offline rcrabb
  •  146 146
« Reply #9 on: February 10, 2007, 11:05:26 PM »
Hang in there. I emailed ART today and it sounds like they are down to only a few things before they finish the POD plugin. Are we sure slaved homeing doesn't work? I wasn't able to get a slaved axis to home, but I didn't try very long. I'll get to testing again soon.
Ryan
