Hello Guest it is November 22, 2026, 06:26:43 PM
Author Topic: 4th Axis calculate steps ?  (Read 14312 times)
« on: February 09, 2013, 11:09:18 AM »
Hello together.
Can someone help me?  I purchased a 4th axis for my mill. Now I have to set the steps in Motortuning.
I got a ratio 1/8 because I have two pulleys on it. One with 12 teeth on the Stepmotor and one on the spindle with 72 teeth.
How do I calculate the steps ??
Thank You
Regards
Re: 4th Axis calculate steps ?
« Reply #2 on: February 09, 2013, 04:19:16 PM »
you have 1/6 ratio if its 12 and 72 pulleys, you also need to know if its a 1.8 degree  stepper you have and also what the microstepping is set to, maybe that is what you were meaning by the 1/8?
« Reply #3 on: February 10, 2013, 02:53:49 AM »
Hello Brett..Hello Hood.
Ok let´s start again ...the values I posted are not correct. I was going by description of the 4.th Axis. But the pulleys are different.
Ok Restart. One pulley got 17 teeth and the pulley on the spindle got 127 teeth. I counted by myself this morning  ;D
OK my calculation was this diameter of the big pulley 82,19mm dia from the small pulley 11,00
If my calculation is correct , we got a ratio of 7.47 . Is this right ?
Now  200*8*7,47 /360=33,2
Is this correct ?
Now my question is , The value of 33,2, is this the value to set in the A-Axis Motortuning as Steps ????  But this are degrees or not and in the Stepsfolder Mach requires mm ...or not?
Thank you
Regards
« Reply #4 on: February 10, 2013, 03:12:24 AM »
You dont need bother working out the diameter of the pulley as all you need to do is divide the teeth on big by teeth on small, much easier :)
Ok your calcs are correct and yes it is degrees in motor tuning if you have the axis set as a rotational. It says Steps per unit and in this case a Unit is degrees.
« Reply #5 on: February 10, 2013, 04:19:04 AM »
Hello Hood,
Ok thank you for the tip.
Tell me , how can I set the Axis as rotational ???
Gio
« Reply #6 on: February 10, 2013, 04:30:07 AM »
It is likely set that way as that is default but its on General Config page on the left hand side.
« Reply #7 on: February 12, 2013, 04:33:18 AM »
Hello Hood ,
Ok Thank you.  I will try this as soon as I got the cable fixed to the controler.... ;D
I got an other question to you...I will write you in PM
regards
