Hello Guest it is November 27, 2026, 10:47:19 PM
Author Topic: TCP ModBus SetUp  (Read 9479 times)
TCP ModBus SetUp
« on: February 08, 2013, 07:14:49 PM »
All,
I just attempted to start the TCP Modbus setup and it wont start, any suggestions ?
Windows Vista - Mach3 Version R3.043.022 ...... everything else is workiing fine.
Re: TCP ModBus SetUp
« Reply #1 on: February 08, 2013, 09:56:16 PM »
Do you have TCP modbus enabled in General config, ports and pins?  Did you close and restart Mach after you enabled it?
« Reply #2 on: February 09, 2013, 05:15:22 PM »
I installed the latest lockdown and it seems to work fine now ......
Thanks for the reponse..
