Hello Guest it is October 21, 2026, 12:57:15 AM
Author Topic: Bugy Mach crashed my machine  (Read 20326 times)
Re: Bugy Mach crashed my machine
« Reply #10 on: February 06, 2013, 02:57:45 PM »
Hello,
ok i will use the older Version which works .
But i have still the Problem, my spindle does not run
If i use the german Version, i can turn on and of, with the original Version it does not start.
I have made the same Settings.
I only need a PWM on Pin 1 of LPT, then my drive starts, but PWM  seems not to be on pin 1.
Can youplease tell me which settings are neccesary
Eberhard
« Reply #11 on: February 06, 2013, 03:00:53 PM »
attach the xml from the German setup and also the one from the current setup and I will look.
« Reply #12 on: February 08, 2013, 10:41:07 AM »
Hi, the problem with the spindle is solved. In the config of ESS PWM was not checked. I have klicked on it, but have forgotten to restart mach3
With the homing-problem, the older Versionof english mach 3 works...
