Hello Guest it is November 12, 2026, 12:21:20 AM
Author Topic: AutoCad 2013 to MeshCAM to Mach3  (Read 9847 times)
« on: January 29, 2013, 05:00:08 AM »
For some reason i am getting scaling in this process, the item shrunk by about 1/3 there has to be some setting somewhere
Re: AutoCad 2013 to MeshCAM to Mach3
« Reply #1 on: January 29, 2013, 12:10:23 PM »
Are you exporting an .stl? Is the model drawn full scale?
What units are you selecting in MeshCAM? WHat post are you using?
What are your native units in Mach3?
The only way it can be off is if it's drawn the wrong size. or if your mixing units somewhere.
import files
« Reply #2 on: February 04, 2013, 03:37:42 PM »
good afternoon fellas ; i can't figure out how to import my mesh cam file in to mach3. there is no import link. what's up with that? thank you for your help, richard the chicken hearted.
« Reply #3 on: February 07, 2013, 04:01:27 PM »
FILE > Load G-Code, then select the file you want to load.
