G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: jstanthr on January 29, 2013, 06:00:08 AM
For some reason i am getting scaling in this process, the item shrunk by about 1/3 there has to be some setting somewhere
Are you exporting an .stl? Is the model drawn full scale?
What units are you selecting in MeshCAM? WHat post are you using?
What are your native units in Mach3?
The only way it can be off is if it's drawn the wrong size. or if your mixing units somewhere.
good afternoon fellas ; i can't figure out how to import my mesh cam file in to mach3. there is no import link. what's up with that? thank you for your help, richard the chicken hearted.
FILE > Load G-Code, then select the file you want to load.
