Hello Guest it is November 13, 2026, 09:07:02 PM
Author Topic: I can only see 2 decimal places on feedrate window  (Read 47584 times)
Offline dresda
  •  220 220
« on: January 21, 2013, 10:42:24 PM »
when running in inch/rev the feedrate window only shows 2 decimal places so if I run at .005"/rev you can't see the 5 what gives..
Ray..
  •  9,377 9,377
Re: I can only see 2 decimal places on feedrate window
« Reply #1 on: January 22, 2013, 12:47:57 AM »
Hi Ray,
You will need to use one of the Screen Designers - opening the .set file (typically 1024.set) the format of the Feedrate DRO's are shown as %4.2f - the 2f is the number of decimals shown - change this figure to 3f if that is the number of decimals you require.
« Reply #2 on: January 22, 2013, 05:57:34 AM »
Inputed or called for feedrate is implemented even though it is not shown in the window as such.
Offline dresda
  •  220 220
« Reply #3 on: January 22, 2013, 01:16:30 PM »
I know I have .005" /rev but would like to see it, I know the 5 is hiding behind the window, should I try another screen set?
« Reply #4 on: January 22, 2013, 01:39:31 PM »
Why not just do what Tweakie mentioned in his post?
Hi Ray,
Offline dresda
  •  220 220
« Reply #5 on: January 22, 2013, 01:47:06 PM »
That's easy for you to say, don't know how to do that. I just try to evaluate this stuff, why wouldn't have that been done as standard on the standard lathe screen, doesn't anyone want to see the feedrate?
« Reply #6 on: January 22, 2013, 02:35:00 PM »
Please take a screen shot of what you see, and I may be able to help out with this.
« Reply #7 on: January 22, 2013, 02:45:17 PM »
See if this is any better for you.
Offline dresda
  •  220 220
« Reply #8 on: January 22, 2013, 06:18:24 PM »
Thanks tweakie and Dave for the mod.
Ray.
« Reply #9 on: January 22, 2013, 06:20:51 PM »
That worked ok for you?
You're very welcome-
