Hello Guest it is October 21, 2026, 06:13:06 AM
Author Topic: Old Guy Needs More Help  (Read 10264 times)
« on: January 21, 2013, 07:19:21 PM »
How come I can not use the keys or drop down to move the machine.  There is something simple I am sure.  All electric is hooked up.  This has happened a couple times and I have been able to get out of it but I am stuck. Please help me out.
OG
Re: Old Guy Needs More Help
« Reply #1 on: January 21, 2013, 07:24:14 PM »
Do you have jogging enabled ?
Toggles on and off from the Run screen (Mill).
Russ
« Reply #2 on: January 21, 2013, 07:40:01 PM »
I thought I did but I will have to go and check.  Let you know.  Thanks
« Reply #3 on: January 21, 2013, 09:43:17 PM »
OK I am fixed for the moment.  This is the jog toggle under the Tool info block.  If I turn it off I can not move around. If I make it go green then I can. Thanks for that.
