Hello
Guest
it is
October 21, 2026, 05:06:31 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Old Guy Needs More Help
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Old Guy Needs More Help (Read 10263 times)
hkstaub2
11
on:
January 21, 2013, 07:19:21 PM »
How come I can not use the keys or drop down to move the machine. There is something simple I am sure. All electric is hooked up. This has happened a couple times and I have been able to get out of it but I am stuck. Please help me out.
OG
Logged
Overloaded
4,923
Re: Old Guy Needs More Help
Reply #1 on:
January 21, 2013, 07:24:14 PM »
Do you have jogging enabled ?
Toggles on and off from the Run screen (Mill).
Russ
Logged
hkstaub2
11
Reply #2 on:
January 21, 2013, 07:40:01 PM »
I thought I did but I will have to go and check. Let you know. Thanks
Logged
hkstaub2
11
Reply #3 on:
January 21, 2013, 09:43:17 PM »
OK I am fixed for the moment. This is the jog toggle under the Tool info block. If I turn it off I can not move around. If I make it go green then I can. Thanks for that.
Logged
Print
Pages:
1
Go Up
« previous
next »
