Hello Guest it is November 04, 2026, 01:02:43 AM
Author Topic: Crossbones for a noob  (Read 32340 times)
« on: January 21, 2013, 11:40:51 AM »
i am new and still having diffuiculties on finishing a project can someone upload this gcode and tell me what actually happens and post the final product thankyou
Re: Crossbones for a noob
« Reply #1 on: January 21, 2013, 06:01:10 PM »
is this what you need?   ???
« Reply #2 on: January 24, 2013, 10:35:45 AM »
yes thats the image but when you carve that how deep does it go and does it actually carve that out? along with how long did it take? Im trying to see what im doing wrong when importing into my 3040t thankyou ya-nvr-no
« Reply #3 on: January 24, 2013, 11:05:43 AM »
Looking at your Gcode you have not set up you tools properly or setup the depth of cut properly.
The top of your material should be Z0.000. This will make all your CUTS to be below Z0.000  such as  Z-0.010 for a .010 cut.  IF you are cutting in steps to get to total depth your would use a Step value say .010 and a final depth of Z0.050. That would cut .010" at a time and repeat five times at a lower depth until it reaches .050" deep
You set the rapid height ABOVE the surface such as Z0.500  Approach heights could be closer to the top such as Z0.050
Hope that helps, (;-) TP
« Reply #4 on: May 18, 2015, 06:43:10 PM »
Hi I am new here and wondering if anyone could shrink the crossbones down.
« Reply #5 on: May 19, 2015, 06:03:46 AM »
pjjr,
Here is a link to conversion program for scale / mm_inches- inches _mm.
You may want to have a look at the complete thread.
http://www.machsupport.com/forum/index.php/topic,2893.msg39920.html#msg39920
« Reply #6 on: May 19, 2015, 10:21:06 AM »
From Mach3 you can use SCALE to make it larger or smaller when you cut it.  Just make sure you scale X and Y the same amount.
