Hello Guest it is October 05, 2026, 09:55:45 PM
Author Topic: Disable E-stop on file load  (Read 8612 times)
« on: January 14, 2013, 05:51:12 PM »
Is there a way to disable the E-stop trigger when a file is loaded? I am using Mach3 on a Reprap style 3d printer, and control my heated elements with the spindle relay. When the E-stop is triggered, I have to wait for my heater PID controllers to cycle and come back to temperature.
Re: Disable E-stop on file load
« Reply #1 on: January 14, 2013, 07:15:52 PM »
Sounds like you may be getting a watchdog error, if so disable it on General Config.
« Reply #2 on: January 14, 2013, 07:35:34 PM »
I have watchdog disabled.
Think I've got it by unchecking 'Turn Off Spindle' under Pgm End settings, and can add a M5 at the end of my gcode to turn turn off the spindle relay/heaters.
« Last Edit: January 14, 2013, 07:49:44 PM by Dirty Steve »
