Hello Guest it is October 21, 2026, 01:00:59 PM
Author Topic: Probe Ignored Error Message  (Read 13564 times)
« on: January 13, 2013, 09:23:11 PM »
I've seen a couple of other threads with the same problem I have:  When probing I get the message " probe ignored activated at call for probe" but no one seems to have the answer for what causes this problem or how to avoid it.  Has anyone experienced this problem and found the solution?
Re: Probe Ignored Error Message
« Reply #1 on: January 14, 2013, 09:50:24 AM »
The message is telling you the when the G31 was called the the probe showed it to be in  a tripped mode  (probe input active).
« Reply #2 on: January 14, 2013, 10:50:18 AM »
Thanks.  I did not notice the Digitize LED was lit.  I'll check for that and wiring problems.
« Reply #3 on: January 15, 2013, 12:09:16 AM »
Thanks again BR549.  With your suggestion, I checked the wiring and found an intermittent ground in one of the probe circuits.  Problem fixed.
