Hello Guest it is November 22, 2026, 09:39:36 AM
Author Topic: Need code for Robotics team robot pic included  (Read 34150 times)
« on: January 07, 2013, 06:27:44 PM »
This will be engraved in Plexiglas on each side of the robot (cnc machine in harbor freight x2 clone)   Mach 3 software
Plexiglas is 3/8 inch thick
LED lights will be added around the edge to make it light up.
if the x can be around 3.5 to 3.75 inch's for the width of the guy.
Thanks,  I just built the machine around Christmas time and still learning.
Paul
Re: Need code for Robotics team robot pic included
« Reply #1 on: January 07, 2013, 06:57:42 PM »
That is an AWFULLY small picture to get any detail off of.
That said here is a Mach3 Gcode file of the pic.
« Reply #2 on: January 07, 2013, 08:02:49 PM »
Thought Id see what it would look like if I converted it using Corel_Draw X5 and Artcam
« Last Edit: January 07, 2013, 08:04:23 PM by Ya-Nvr-No »
« Reply #3 on: January 08, 2013, 05:44:41 AM »
Paul,
Hope the team does well in the competition and they have fun.
Ya-Nvr-No can you post the gcode?
BTW folks, the robotics teams provide a great way to introduce young folks to so manny things .
Some of these kids end up showing some real talents and aquire new interests.One local team here
has a gal who does all the welding on the robot. Another member is a cracker jack programmer, one
ended up building a cnc machine.
There is a time limit on when they start and finish their robot.
You may have one near you.......thus sharing your knowledge, talents and facilities is a great way to experience a large reward.
« Reply #4 on: January 08, 2013, 06:30:34 AM »
Sorry never created a post as of yet.
But, if and I do I'll probably change the size and do a 3d relief and wrap it around a half log.  I thought the image was very cute.
Terry (TP) provided a fine trace cutout.
Good Luck Kids & Happy New Year
« Reply #5 on: January 08, 2013, 11:32:17 AM »
Ya-Nvr-No, Do you have a large copy of the artwork in say Jpeg or BMG OR BEST OF all a vector image ? What I did was from a very very small image not great for detail.
We want him to have the best (;-)
« Reply #6 on: January 08, 2013, 06:09:37 PM »
What is a BMG file? :-\
« Reply #7 on: January 08, 2013, 08:07:23 PM »
You know one of those BMP's only with a G (;-)
« Reply #8 on: January 08, 2013, 10:29:45 PM »
BR549  THANKS,  I got a engraving on to pexi.  is there a way to rotate the image and the g-gode 90 degrees so he is engraved sideways? See attached image
What program do you use to generate the code?  Thanks
Sorry about the small image,  the team picked a picture they found on the internet (The team name is Stale Marshmallows)
« Reply #9 on: January 09, 2013, 12:00:37 PM »
OK here is the code rotated.
I started with teh very small image and opened in window Photo gallery.  It fits the small image to a larger size for viewing. I then did a PrintScreen and brought it into PAINT. Cleaned up the noise a bit and saved .
Then open in Inkscape and do a Image trace then reduced nodes and saved as a DXF.
Then open in SheetCam ( The best sheet goods CAM) and setup for the engrave operation and saved out as Gcode file.
You can use the new filw OR you could simple rotate your old file in MAch3 with a G68 call OR into -90 in the corrd rotation box.
