Hello Guest it is October 20, 2026, 02:56:30 PM
Author Topic: Rotary axis position issue  (Read 28994 times)
Offline WMT
  •  22 22
    • www.intaglio.co.nz
« on: January 04, 2013, 10:51:08 PM »
Has anyone had trouble with their rotary axis going the long way around in G1 mode?
If I feed G1 A10 F100 from Zero. It Feeds
If I G1 A9 from A10 it goes the long way around instead of moving 1 degree.
I have the rollover box ticked in general config andthe other one that makes the G0 take the shortest route.
Current Version of Mach3 is 3.043.062
Any suggestions would be greatly appreciated
Cheers ???
Re: Rotary axis position issue
« Reply #1 on: January 04, 2013, 11:07:17 PM »
Uncheck the Rot 360 rollover. I think a bug creeped in.
Offline WMT
  •  22 22
« Reply #2 on: January 05, 2013, 12:26:11 AM »
I did that and it now works correctly for G1.
Thank you.
But why have the ability to go above 360 degrees?
« Reply #3 on: January 05, 2013, 01:29:31 AM »
G1 A-9 F100 will move it back when rollover is chosen.
Offline WMT
  •  22 22
« Reply #4 on: January 05, 2013, 01:48:25 AM »
Hi Hood. Yes that works. But my post processor wont add the - "minus" if there is a direction change. And its too hard to go through 7500 blocks of G code to figure out which ones to add a minus too.
« Reply #5 on: January 05, 2013, 02:07:10 AM »
Either you will have to adjust the PP to do so or just disable the rollover.
It has been that way as long as I can recall.
Offline WMT
  •  22 22
« Reply #6 on: January 05, 2013, 03:08:00 AM »
Thanks Hood.  Do you know why there is a need to count more than 360 degrees?
« Reply #7 on: January 05, 2013, 03:14:10 AM »
One situation may be if you were wishing to use the A axis for a spindle so you could have rigid tapping (assuming its a servo or stepper spindle)then you would likely not want the roll over.
Offline WMT
  •  22 22
« Reply #8 on: January 05, 2013, 03:45:38 AM »
That makes plenty of sense. If any one wants to check it out. Ive put a short clip on Youtube https://www.youtube.com/watch?v=MckXFOyQBtw&feature=player_detailpage#t=2s
« Reply #9 on: January 05, 2013, 04:05:04 AM »
Looks very nice, do you have a build thread for it?
