Hello Guest it is October 20, 2026, 04:02:23 PM
Author Topic: DeskEngrave WIZARD  (Read 11240 times)
DeskEngrave WIZARD
« on: January 03, 2013, 09:40:35 PM »
HIYA DUDES, I figured out a easy way to USE Deskengrave from inside a Mach3 Wizard. The results is you can create your Engraving code from ANY system FONT then import it into Mach3 FROM the Wizard. From there you can run the Engrave Gcode.
Not sure it would be handy but it appears to be from here.
What do yall think ? worth finishing up???
« Last Edit: January 03, 2013, 09:43:20 PM by BR549 »
Re: DeskEngrave WIZARD
« Reply #1 on: January 04, 2013, 03:25:12 AM »
Added some more features such as partscale and xy extents so you can see the SIZE of the engraving and adjust if needed.
Took a while to find enough VB code to make the shell out and back work correctly and some more time to find enough code to make the auto file load work with DeskEngrave.
Hopefully it Should be usefull to those who engrave.  Does arc and angle and straight  ,  Scale up and down
« Last Edit: January 04, 2013, 03:26:46 AM by BR549 »
  •  9,374 9,374
« Reply #2 on: January 04, 2013, 04:40:57 AM »
Sounds pretty useful to me, a great idea.  8)
« Reply #3 on: May 09, 2015, 09:31:11 PM »
HOLA DONDE PUEDO DESCARGAR EL  DeskEngrave  WIZARD PARA MACH3 GRACIAS
