Hello Guest it is November 22, 2026, 11:11:45 AM
Author Topic: need help with config  (Read 9667 times)
« on: December 29, 2012, 09:45:53 AM »
I have been running my machine with Turbo CNC for about three years and decided to run it with Mach3.
Home built machine using Hobby CNC board.
No matter what I try I can not get the steppers to work.
I have watch the set up videos a number of time and can not figure out what I am doing wrong.
Printer port is set
X Y Z pins are set
no stop are on
Below is a screen shot of what I have in the diagnostics screen and in the upper left hand corner none of the X Y Z lights are green and in all the set up videos they are red, No matter what I do I can not get them to turn red. ?????
Thanks for your help.
Milton
Re: need help with config
« Reply #1 on: December 29, 2012, 12:03:30 PM »
X Y Z LEDs will be red until you home, then they will go green.
Attach your xml and I will see if there is an issue with it.
« Reply #2 on: December 29, 2012, 04:18:17 PM »
Thanks for the replay but got it working, Had the velocity set to high but not happy with the speed, Can only get about 60" a min without it skipping.
Still can not get the lights to go green.
Milton
« Reply #3 on: December 29, 2012, 05:10:59 PM »
acceleration is likely too high.
