Hello Guest it is October 21, 2026, 08:16:20 PM
Author Topic: Inch to Metric  (Read 10485 times)
Inch to Metric
« on: December 24, 2012, 08:11:33 PM »
I have a file to cut and the cad file that I imported to Cambam was a metric file. I need to be able to cut it on my machine and need to know what I need to do to get it done.
I have attached the gcode and dxf file
Thanks to anyone who could help
Re: Inch to Metric
« Reply #1 on: December 24, 2012, 08:43:14 PM »
You could change the "G20" at the beginning of your gcode file to "G21" and it may cut correctly.
John
Re: Inch to Metric
« Reply #2 on: December 24, 2012, 09:29:05 PM »
Open the DXF file in CamBam, select All, right click and select ' transform ' then ' resize ' then select 'preserve aspect ratio' and click on ' mm to inch '
Hope this helps..
Re: Inch to Metric
« Reply #3 on: December 24, 2012, 10:06:20 PM »
Polska,  Thanks that seems to work. I will cut it in the morning. Im new to cnc machines and still on the steep slope.
Merry Christmas to everyone
Re: Inch to Metric
« Reply #4 on: December 28, 2012, 07:57:09 AM »
When setting up Mach3 personal profile can you do two, One for mm and one for inches and them not interfere with each other.
  Milton
