Hello Guest it is October 05, 2026, 06:41:56 AM
Author Topic: How do you change motor direction.  (Read 27127 times)
« on: December 19, 2012, 09:20:36 PM »
  I have x axis moving in the +X with both arrow keys.
I have Y doing the same thing.
I have Z that is dead.
Could use any help that you have.
R/C guy / Working in shop with a new products designer / I have a ACER 3VK Mill With MACH3 and a DRO II 3M on it.
  •  9,374 9,374
Re: How do you change motor direction.
« Reply #1 on: December 20, 2012, 02:13:40 AM »
Check that you have the correct Port & Pin allocation for Step and Direction for each axis (Config / Ports & Pins / Motor Outputs).
« Reply #2 on: December 20, 2012, 02:18:58 AM »
Still waiting on your xml for your previous post ;) Also still a lack of info on what you actually have. I have never heard of PC Card Maker as a controller or breakout board, maybe if you could attach some pictures or a link to where you got the hardware from people may be able to help.
« Reply #3 on: December 20, 2012, 05:35:55 AM »
Based on the other post, guess he decided to have an extraction.  ;D
« Reply #4 on: December 20, 2012, 05:53:48 AM »
I am neither a dentist or a mind reader so I wish him luck. Only thing I found when I did a google for info on the card he mentioned was a post on the Zone by him and there was as much info in it as here sadly.
« Reply #5 on: December 20, 2012, 12:23:39 PM »
  I am new to this so i do apologize for lack of info. ???
I will go to shop again today and try and get more info on it for you.
I too did not find any info on PC card Maker either,  that was what i was told who made card.
I worked on it from 12:30 till 111:30 at night with no luck.
Went threw Manual several time's and i mean several time's and could not find anything out.
Strange thing is i seen it work before 6 months ago.
When i had some help tracing threw everything yesterday i found one connection had come undone.
I learned there is a momentary button that needs to be pushed in to get the driver boards to light up green.
This X Y Z Thing is really driving me nuts, i need info on the Motor output settings but do not know where to look for info on ports and pins yet.
I will post some photos and take some more detailed one's today.
Thanks for your help.
« Last Edit: December 20, 2012, 12:34:55 PM by gtxkid »
« Reply #6 on: December 20, 2012, 12:26:42 PM »
Would it be possible to also scan the manual to a pdf and attach?
« Reply #7 on: December 20, 2012, 12:41:00 PM »
  I did edit what i said above  check it out
I printed the manual off of this sight.   http://www.machsupport.com/docs/Mach3Mill_Install_Config.pdf
Is the only one i have.
« Reply #8 on: December 20, 2012, 12:54:00 PM »
  New info:
I think the correct name of the board is: CNC 4 PC
I also know the pin out need to be checked on the Z axis.
« Reply #9 on: December 20, 2012, 01:53:51 PM »
Ok thats a good start, Arturo at CNC4PC makes quite a few different breakout boards but you should be able to find a manual for the one you have from his site.
