Hello Guest it is November 25, 2026, 03:01:48 AM
Author Topic: Galil 41X4  (Read 11162 times)
Galil 41X4
« on: December 17, 2012, 12:03:45 PM »
I have a mill with Galil 41x4 running. I am totally a novice at this so forgive the stupidity and somtimes stupid question. There are 2 item I would luv to pursue.
1: What Mach3 wizards can I run thru the Galil setup.
2: Can  I use the Homann MP-03 with this setup theu the 9 pin setup.
racear
Offline kcrouch
  •  193 193
  • In way too deep!!!
Re: Galil 41X4
« Reply #1 on: December 17, 2012, 02:24:54 PM »
racecar,
I have had trouble with the Modbus based stuff that needs to pass data quickly to Mach. There is a 100ms latency that may cause jerky motion should not be a problem when Mach4 is out). I have been successful with the MPG-04 from CNC4PC. Any MPG will likely need brain files to get proper communication with Mach.
Cheers,
Kenny
Having way too much fun! Something must surely be wrong.
Re: Galil 41X4
« Reply #2 on: December 17, 2012, 06:48:43 PM »
Now Kenny, u just aint makin me feel warm inside with that answer. Can we discuss it.
racear
Offline kcrouch
  •  193 193
Re: Galil 41X4
« Reply #3 on: December 17, 2012, 07:02:47 PM »
Not to worry you, the hardwired MPG (into the Galil inputs) works very well indeed and the brain files aren't too hard to do either. I just am not comfortable with motion depending on a device that only communicates every 100ms either. Think broken tools or worse!
