Hello Guest it is November 23, 2026, 12:12:15 PM
Author Topic: z steper trouble  (Read 73974 times)
z steper trouble
« on: December 14, 2012, 07:25:27 PM »
Z code looses the computer after a code post and just keeps going. Nothing on the computer stops it. Only E-Stop does and if you don't clear the DRO it will start back up when you reset the E-Stop.
Code G01 Z1.0000 and the DRO moves to 0.0001 and that's where it stays. The mill will lower till it bottoms out or you hit E-Stop.
I was resetting the steps when this started and I have checked the steps and that is right, I checked the stepper cable and it has continuity at all pins, , Whats next please.
Re: z steper trouble
« Reply #1 on: December 15, 2012, 05:46:43 AM »
Attach your xml and I will have a look and see if I can find an issue.
« Reply #2 on: December 15, 2012, 07:02:49 AM »
do you have a virus protector on the computer.?
« Reply #3 on: December 15, 2012, 10:33:18 AM »
I have Norton
« Reply #4 on: December 15, 2012, 10:34:24 AM »
remove it completely, i've seen this move an axis before.
« Reply #5 on: December 15, 2012, 04:24:16 PM »
XML  File
« Reply #6 on: December 15, 2012, 04:51:07 PM »
Afraid that is not your xml you have attached.
« Reply #7 on: December 16, 2012, 12:42:22 AM »
try this again
« Reply #8 on: December 16, 2012, 07:09:09 AM »
Dont see anything wrong in your xml so really it sounds like a hardware issue. This is especially so as you say the DRO in Mach stops, Mach gets its readings in the DRO from monitoring the pulses it puts out at the PP so it would seem to suggest hardware.
Dont suppose you have a scope? If you do you sould confirm whether that is the case or not.
« Reply #9 on: December 16, 2012, 10:34:05 AM »
I don't have a scope. I don't know even if I could rent one.
