Hello Guest it is November 12, 2026, 12:31:38 AM
Author Topic: D-value in Peck Drilling Cycles  (Read 8085 times)
« on: December 13, 2012, 12:13:18 PM »
Hi All,
  Can anyone tell me if there is a way to adjust the point where the drill switches from rapid to feed during each peck in a G83 cycle?  It seems the default is 0.01" but I can't find any way to change this.  I saw one other thread where somebody mentioned this but I couldn't find an answer.  I want to decrease this value because I'm drilling through crystalline silicon with a diamond plated bit and my peck depth has to be <0.001" so with  D=.01"  less than 10% of the time is spent actually removing material.  I'd like to speed this up.
thanks!!!   BTW i'm using a TAIG with a DSLS 3000 controller from Microproto.
-David
Re: D-value in Peck Drilling Cycles
« Reply #1 on: December 13, 2012, 02:04:04 PM »
Look in Config  Ports/pins   Mill options    Look for    G73 pull back
Not really sure if that is what you are lookng for. BUT try it.
