Hello Guest it is November 22, 2026, 04:08:21 PM
Author Topic: How to Jog X+ with an external switch  (Read 8921 times)
« on: December 11, 2012, 12:54:24 AM »
Is there a way to jog X+ (Right arrow) from an external switch without a keyboard emulator?
Is there an OEM code for that or is this a dumb question?
I am running 2 screen functions with external switches, so OEM codes work there.
Could someone explain the EMULATED input check box on Input pins- How that works -  could use 2 more external switches - I'm Poor at electronics
Thanks  Jack Hoffa
jack.darlene.hoffa@roadrunner.com
Re: How to Jog X+ with an external switch
« Reply #1 on: December 11, 2012, 02:06:44 AM »
Put your switch to an input pin then go to ports and Pins then Inputs and scroll down near the bottom and you will see the Jog button options. Set the port and pin number you have the switch connected to for x++ and you are done :)
« Reply #2 on: December 11, 2012, 12:12:24 PM »
THANKS SOO MUCH
I didn't go down the list far enough
Jack   ::)
