Hello Guest it is October 10, 2026, 08:03:06 PM
Author Topic: Safe version # for Turn?  (Read 10376 times)
« on: December 09, 2012, 04:05:45 PM »
What's the least buggy version of Mach 3 Turn?  Mine is R3.043.022
I've finally got my opto home switches up & working on the ORAC and want to get this thing into a solid configuration.  I'm pretty sure the weird things it's doing are due to my ignorance but I want to make sure I'm starting with as solid a version as possible as I go forward.  What version are you guys using that actually make parts consistently with your lathes?  I'm using a solid PC with a good PP (no external controller.)
Milton from Tennessee ya'll.
Re: Safe version # for Turn?
« Reply #1 on: December 09, 2012, 04:23:24 PM »
For  threading should be > than 3.042.033. You may want to check Ron's recomendations if using the NFS Turn wizard.
« Reply #2 on: December 09, 2012, 04:51:21 PM »
Thanks Rich, I'll install .033 and go from there.
« Reply #3 on: December 09, 2012, 07:55:38 PM »
Hmmm, went to the old versions page and their isn't an .033 version listed??
