Hello Guest it is November 17, 2026, 11:51:13 AM
Author Topic: Slaving over a hot Pod  (Read 162412 times)
Offline kookaburra
  •  56 56
  • Fussy? Yep! That's Me ;)
    • Akela Website
Re: Slaving over a hot Pod
« Reply #10 on: January 18, 2007, 04:31:04 PM »
greolt,
I will try slaving my axes and see what I get. I am just about to go into a meeting so it may be a little while before I get to it. Best for me to try first before you go and re wire you machine in the hope of reducing any noise issue that may not be there.
Regards
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
"If you think you are under pressure - Try opening a sippy cup on an airoplane - 30,000ft in the air"
Greetings From Down Under
Dave Drain
Akela Noble Technologies Pty. Ltd.
Offline Greolt
  •  956 956
« Reply #11 on: January 18, 2007, 05:34:06 PM »
Yeah no worries Dave.
Please be aware I am not a user desperatly seeking support to get his machine going.
Just someone who is interested in the advent of the ncPod and similar devices.
It is quite possible that my input simply "muddies the waters" and would be better to
leave this type of posting to more "expert" users.
Thanks,   Greg
Offline Greolt
  •  956 956
« Reply #12 on: January 20, 2007, 09:36:34 PM »
I was wondering if any beta users out there are having success with the slaving function.
Not sure whether I am just doing something wrong or if others are having the same issues.
Offline rcrabb
  •  146 146
« Reply #13 on: January 20, 2007, 09:53:19 PM »
I'll go try to set up a slave now. I'll report back.
Ryan
Offline rcrabb
  •  146 146
« Reply #14 on: January 20, 2007, 10:01:11 PM »
I just slaved my A axis to my X and everything worked. I didn't do any perfomance test but the axis moved together.
Ryan
Offline kookaburra
  •  56 56
    • Akela Website
« Reply #15 on: January 20, 2007, 10:14:59 PM »
Thanks for letting us know Ryan.
Guys, I have to go away for a few days, I will try to check in while I am away, but if I seem a bit quiet, thats why. I will be back next Wednesday.
Take Care
Dave Drain
Offline Greolt
  •  956 956
« Reply #16 on: January 20, 2007, 11:56:13 PM »
OK thanks for that Ryan.
I must be doing something wrong, however I am working on my Y and Z axis now so can't play with
the Pod for the moment.  When I get that done I will be asking more questions.  ;D
Offline kookaburra
  •  56 56
    • Akela Website
« Reply #17 on: January 26, 2007, 05:15:03 PM »
Good luck with the retro Greolt, I bet you are looking forward to seeing all the Axes finished and moving well.
Regards
Dave Drain
Offline Greolt
  •  956 956
« Reply #18 on: January 26, 2007, 06:06:48 PM »
Sent you a PM dave  :)
Offline kookaburra
  •  56 56
    • Akela Website
« Reply #19 on: January 30, 2007, 06:38:46 PM »
Got it
Dave Drain
