Hello Guest it is November 17, 2026, 11:51:41 AM
Author Topic: Slaving over a hot Pod  (Read 162423 times)
Offline Greolt
  •  956 956
« on: January 17, 2007, 11:06:11 PM »
 I am building a router that has R&P drive on each side of the X axis.
Although the Y and Z axis are not done the slaving in Mach through LPT has tested well on the completed X
So as Art has released a plugin for the Pod that has slaving I thought I would give it a go  :)
One side of the drive is designated X and the other side A.  Slaving is selected in Mach X to A
Motor tuning is set the same to both drives.  Try to jog. No go. Just acts like it is stalling. (turns slowly, makes a lot of noise)
Tried all sorts of velocity and accelleration settings. Nothing works.
Deselect slaving and X jogs perfectly on its own.
What am I doing wrong. Something stupid I guess.  ;D
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Slaving over a hot Pod
« Reply #1 on: January 18, 2007, 02:23:58 AM »
Have you got the 2 motors running in the same direction?
Are they mounted mirror style or in parallel?
If mirrored they need to run in opposite directions.
Graham.
Offline Greolt
  •  956 956
« Reply #2 on: January 18, 2007, 05:10:01 AM »
Motors are set to run in the correct direction. They are not fighting one another.
Being R&P I can simply release the spring that holds the pinion against the rack untill rotation direction is set correct.
Incidently I could not simply toggle "direction low active" to reverse motor direction as you can when using LPT.
Had to physically reverse two motor wires.
« Reply #3 on: January 18, 2007, 05:18:58 AM »
Can you swap your motor wires at the drives? Make x=a and a=x. This might help narrow it down. Before you do that, have you tried the a axis with the x axis disabled?
Offline Greolt
  •  956 956
« Reply #4 on: January 18, 2007, 05:43:34 AM »
When X and A is slaved together no go. When slaving disabled both axis jog perfectly independantly.
Of course I have disengaged one pinion.
Wire it back up to LPT and slaving works as it should.
Fairly certain it is not a mechanical, driver or motor problem. Just something to do with slaving with the Pod.
Thanks,  Greg
« Reply #5 on: January 18, 2007, 05:46:49 AM »
Are you saying all is well with both engaged now?
Offline Greolt
  •  956 956
« Reply #6 on: January 18, 2007, 05:53:47 AM »
Sorry I think you misunderstood Brett.  I have been trying to get slaving going using the Pod.
LPT works but I only mentioned that to demonstrate that I don't believe it is a mechanical problem.
It is slaving with the Pod that I am posting about.
« Reply #7 on: January 18, 2007, 05:57:04 AM »
Your right, I did misunderstand. Sorry about that. Yes, I doubt it is in your setup.
Offline kookaburra
  •  56 56
  • Fussy? Yep! That's Me ;)
    • Akela Website
« Reply #8 on: January 18, 2007, 01:18:40 PM »
Greolt,
Sounds like there might be a problem with the slaving function. Do me a favour, can you disengage the A axis motor and try to slave X and Y together. If this works, disengage your X axis Motor and re-engage your A axis and slave Y and A together. Let us know the outcome.
On the Motor reversal issue, the place to do that for the POD is in your Homing/Limits in the config not in Ports and Pins. In the table in this section under Home/Limits, the first column will allow you to reverse the motor direction, this works, I had to do it on my machine.
Hope to hear the results soon.
Regards
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
"If you think you are under pressure - Try opening a sippy cup on an airoplane - 30,000ft in the air"
Greetings From Down Under
Dave Drain
Akela Noble Technologies Pty. Ltd.
Offline Greolt
  •  956 956
« Reply #9 on: January 18, 2007, 04:08:14 PM »
Yes that was the right place to reverse motor direction.  Had not noticed that before.  :D
As I said in the first post this half built machine up to now only has two motors, both driving the X from both sides.
However in response to your request I tried those two motors in every combination I could by
plugging them into the Pod as X, Y, Z, A, B. and C
Every time slaving would not work and with slaving deselected each motor would jog perfectly as an individual.
Could it be a noise issue? Wiring is physically separated but not shielded.
As signal should be identical when slaved it would not be a problem. Wouldn't it.  ???
I spose if slaving is working for everyone else then something like that may explain it.
