Hello Guest it is October 20, 2026, 05:06:08 PM
Author Topic: Strange 8 second delay on M03  (Read 12320 times)
« on: December 05, 2012, 10:42:09 AM »
Whilst configuring my new spindle I seem to have introduced a delay on spindle start (M03) of about 8 seconds.
I've since disabled the spindle control plugin and reset all the config values back the way they were, but the delay seems to persist.
Sometimes it triggers a watchdog timer and reset.
Any ideas how I can get back to normal operation?
Steve
Re: Strange 8 second delay on M03
« Reply #1 on: December 05, 2012, 12:23:27 PM »
You mention the spindle control plugin, what plugin are you using?
Could it be a delay on General Config page you have set?
« Reply #2 on: December 05, 2012, 12:27:21 PM »
It was the "new" plugin for the Huanyang vfd.
I will go back and check the General Config page, but I'm pretty sure I cleared all the values I entered.
« Reply #3 on: December 05, 2012, 12:35:14 PM »
Ok dont know of that plugin, wondering however if it has written the delay to the xml and even though you did away with the plugin the delay has persisted. You could try setting maybe a 1 second delay in General Config and see if the delay is reduced, if it is then go back in and set to zero and see.
« Reply #4 on: December 05, 2012, 12:38:36 PM »
I can check on that later today - it doesn't stop me from working, but just delays things a bit ;-)
« Reply #5 on: December 05, 2012, 12:40:36 PM »
Ha ha it would drive me up the wall and I would be kicking things ;D
