Hello Guest it is October 02, 2026, 08:07:43 AM
Author Topic: new controls  (Read 11824 times)
Offline greg
  •  66 66
new controls
« on: January 27, 2007, 11:02:45 PM »
i have a taig mill with xylotex control and mach3. i am planing on getting a bigger mill or a router, when i do i want a closed loop system. i do not know if i want steppers or servos? if i stay with steppers and the lpt ports i know i can get a rogers machine second lpt and that will work? if i do not want to stay with the lpt can i is stall encoders and have it work the same useing either the nc pod or the grex? thanks in advance. greg
Re: new controls
« Reply #1 on: January 28, 2007, 12:30:15 PM »
You will not get closed loop by either method, you will get semi closed loop though. For full closed loop I think you will need to go with a Galil but Brian would be the person to ask as far as that is concerned.
  I would think you could connect Rons board via a pod or whaetever by hacking up a parallel port cable  but I am not 100% sure, but cant see why not.
Re: new controls
« Reply #2 on: January 28, 2007, 09:32:33 PM »
Galil or deltaTau in the near future ;)
www.newfangledsolutions.com
www.machsupport.com
Offline greg
  •  66 66
Re: new controls
« Reply #3 on: March 16, 2007, 06:29:18 AM »
 brian will a galil 1832 motion control card work with other kinds of dries or do the driver, amps need to be galil also? thanks greg ;)
Re: new controls
« Reply #4 on: March 16, 2007, 07:10:34 AM »
The Galil will work with about any drive :)
www.machsupport.com
