Hello
Guest
it is
November 25, 2026, 03:13:58 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Galil
(Moderators:
smurph
kcrouch
Galil controlling drives in torque mode?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Galil controlling drives in torque mode? (Read 10310 times)
gavztheouch
1
on:
November 29, 2012, 04:04:12 PM »
When using a Galil control system to control external anologe servo drives. Would I only need to tune the motors within the Galil board itself?
When running an ac servo drive in torque mode, is the drive simply varying current to the motor and allowing the galil to perform all calculations?
kcrouch
193
In way too deep!!!
Re: Galil controlling drives in torque mode?
Reply #1 on:
December 03, 2012, 12:46:56 PM »
You'll need to configure (and wire) the drives to use a -10, 0, +10v signal and then tune the Galil board servo settings. Some drives will run smoother when set to velocity mode, so you'll need to experiment some.
Having way too much fun! Something must surely be wrong.
Print
Pages:
1
Go Up
« previous
next »
