Hello Guest it is November 25, 2026, 03:13:56 AM
Author Topic: Galil controlling drives in torque mode?  (Read 10309 times)
« on: November 29, 2012, 04:04:12 PM »
When using a Galil control system to control external anologe servo drives. Would I only need to tune the motors within the Galil board itself?
When running an ac servo drive in torque mode, is the drive simply varying current to the motor and allowing the galil to perform all calculations?
Offline kcrouch
  •  193 193
  • In way too deep!!!
Re: Galil controlling drives in torque mode?
« Reply #1 on: December 03, 2012, 12:46:56 PM »
You'll need to configure (and wire) the drives to use a -10, 0, +10v signal and then tune the Galil board servo settings. Some drives will run smoother when set to velocity mode, so you'll need to experiment some.
Having way too much fun! Something must surely be wrong.
