Hello Guest it is November 07, 2026, 03:19:45 AM
Author Topic: Drilling cycle from Bobcad  (Read 16150 times)
« on: November 29, 2012, 12:29:24 PM »
I am trying to CNC a cribbage board designed in BobCAD/CAM (BCC) V21.  In the past I would draw the hole, offset the radius of cutter inside the hole and make the hole by selecting the offset.  In this case the holes are 1/8" and I would just like to drill them with a 1/8" end mill.  On a three track 120 point cribbage board this is over 360 holes.
I have the V21 training videos and they show exactly what I want to do.  They use a "G81" and "G73 with Q" cycles from another post processor.  They select the true "holes" and the cycles use the center of the "holes" to position the mill and then drill.
The post processor for Mach isn't working the same as the video with the other post processor. Instead of drilling the center of the geometry (hole) it follows the geometry outside diameter.  Actually, I'm not sure the drilling cycle is working at all.
BCC doesn't (as far as I can figure out) allow you to use an arc center point in the CAD side to select for a CAM side action.
Has anyone conquered this?
Is there a way to change the drill script in the post processor?  If so, what should it read?
Steve.
Re: Drilling cycle from Bobcad
« Reply #1 on: November 29, 2012, 12:47:08 PM »
NOrmally you just set a point for drilling. Then select the tool and drill cycle.
This is a question best asked BOBCAM.
« Reply #2 on: November 29, 2012, 01:34:22 PM »
"This is a question best asked BOBCAM."  Sales questions are free and fast, technical questions on a prior product - not so much.
Steve.
Re: Drilling cycle from Bobcad - Solved
« Reply #3 on: November 30, 2012, 11:28:15 AM »
Solved it.  User problem, didn't figure out that R is from Z0.  Thought R (retract) distance was from depth of Z.
N1G70
N2 M6 T1
N3G81X1.0188Y6.7615 Z-.375 R.125 F10 G99
N4X12.9995Y6.9995
N5X12.9942Y7.2508
N6X12.9785Y7.5016
N7X12.9155Y8.0001
N8X12.8684Y8.247
N384Y6.25
N385G80
Steve.
« Last Edit: November 30, 2012, 11:30:09 AM by sawduststeve »
« Reply #4 on: November 30, 2012, 12:13:09 PM »
For future reference, CNC Zone has some helpful BobCAD users.
« Reply #5 on: November 30, 2012, 01:15:37 PM »
"For future reference, CNC Zone has some helpful BobCAD users."
Gerry -  A shame actually, the software is pretty good and reasonable in price for the features.  You have to get any online support from 3rd party sites.  Support to prior version users, except for the constant classes, has eroded to near nothing on their forum.  I have V24, but prefer V21 for anything 2D.  - Steve.
