Hello Guest it is October 24, 2026, 01:13:51 AM
Author Topic: Mach3 Thread Mill Wizard Help  (Read 8291 times)
« on: November 29, 2012, 11:42:31 AM »
I am using Mach 3 ver R3.042.029 on a Tormach PCNC1100. An example Thread
Mill Wizard from Mach3 is a 1-8 outside thread shown below for a single form
cutter.
G0 G49 G40  G17 G80 G50 G90
M6 T46 (TOOL DIA. 0.504)
G20 (Inch)
M03 S1000
G64
G00 G43 H46  Z0
(Right hand OD Climb)
X1.075 Y0.2875
G01 Z0.0625 F15
G01 G41 P0.25 X0.7875 F15
G03 X0.5 Y0 R0.2875
G02 X-0.5 Y0 R0.5 Z0
G02 X0.5 Y0 R0.5 Z-0.0625
G02 X-0.5 Y0 R0.5 Z-0.125
G02 X0.5 Y0 R0.5 Z-0.1875
G03 X0.7875 Y-0.2875 R0.2875
G01 G40 X1.075
G00 Z0
M5 M9
M30
I want to add a finish pass at the bottom of this outside thread where there
is no change in Z. This is to give the bolt part a smooth shoulder that a
nut (inside thread) can butt up against and not show any exposed threads on
the shaft of the bolt. See starred lines in G-code below.
G20 (Inch)
M03 S1000
G64
G00 G43 H46  Z0
X1.075 Y0.2875
G01 Z0.0625 F15
G03 X0.5 Y0 R0.2875
G02 X-0.5 Y0 R0.5 Z-0.1875 * (this line added by me)
G02 X0.5 Y0 R0.5 Z-0.1875 * (this line added by me)
G01 G40 X1.075
G00 Z0
M5 M9
M30
When I just add a circular (Z not changing) pass after the last helical pass
(Z dropping) using the exact same X,Y, and R parameters Mach 3 gives me an
error that the tool path is ending at the same point that the previous tool
path ended at. Mach won't allow this but this is exactly what I want it to
do.
To get around this I have to do a dummy G01 out away from the work and then
another G01 back to the same starting point. Thereafter, the circular pass
is allowed and worksfine. See Below.
G20 (Inch)
M03 S1000
G64
G00 G43 H46  Z0
X1.075 Y0.2875
G01 Z0.0625 F15
G03 X0.5 Y0 R0.2875
G01 X1 Y0 * (this line added by me)
G01 X.5 Y0 * (this line added by me)
G01 G40 X1.075
G00 Z0
M5 M9
M30
Why does Mach make me go to this extra effort? It seems like a waste of time
and code. I think the problem is in Mach not Thread Wizard.
Mark
