Hello Guest it is November 25, 2026, 04:04:13 AM
Author Topic: Hi all, new guy struggling with DC-03 & mach  (Read 37466 times)
« on: November 28, 2012, 01:56:46 AM »
hi guys
have been lurking around here for a bit.  there are some great conversions and very knowledgeable people kicking around here.
i have a BP clone mill that i have converted using 400w yaskawa servos.  so far all going well, only a couple of issues that were more related to hardware than anything else.
due to how user friendly mach 3 is i have got through the conversion reasonably pain free but this latest issue has me stumped.
i have been running the mill for a couple of months and now want to get the spindle speed up and running.  i was only using the dc03 from peter homann for on/off duty but now want to use it to vary speed.
i have had email conversation with Peter about my issue but it looks like his board is set up, wired and should operate correctly. i have also email him some screen shots of my mach setup and it all looks right.
i have taken pics of my dc03 setup and he confirmed it seems correct but it doesn't matter what i do all i get is 100% speed output from the unit. when i power up the board i get the correct flashes and when i activate the pins i get the fast flash saying the board has signal.  if i deactivate the pin in mach 3 the flash on the dc03 changes to say it is getting no signal.
so my question is how do  i tell if machi3 is outputting the PWM to the board?
i am sure it will be something basic but i have spent literally hours trying to get this thing working but no joy.  i have used a pot on the inverter to confirm i have the inverter set correctly and when i put the dc03 in trimpot mode and turn the on board pot the speed changes accordingly.  got me stuffed
any ideas?
« Last Edit: November 28, 2012, 01:59:27 AM by DeanoM »
Re: Hi all, new guy struggling with DC-03 & mach
« Reply #1 on: November 30, 2012, 01:20:26 AM »
just tried a new pc and still nothing.  all i get is the max voltage output from the dc03 giving me only max rpm with no adjustment
a real pain in the arse cause i know it will be a dead simple fix but at this stage i can't see it and have no idea how to test for a pwm signal from the pc.
like i mentioned the led on the dc03 flashes fast like it is recieving a signal but what signal it is getting i have no idea.
also maybe this board cant run via a eternet s/stepper.  is anyone using this combination already?
« Reply #2 on: November 30, 2012, 04:40:38 AM »
Peter would be the best guy to help you but but if you want to attach your xml I will see if I can find anything wrong in it.
« Reply #3 on: November 30, 2012, 03:32:01 PM »
i agree, have sent Peter another email last night.
i will attach xml file.
thanks
« Last Edit: November 30, 2012, 03:36:08 PM by DeanoM »
« Reply #4 on: November 30, 2012, 03:37:05 PM »
DID you set up the spindle in MACH# to run as a PWM spindle and calibrate it correctly ??
« Reply #5 on: November 30, 2012, 03:41:29 PM »
Terry, I think that is done in the SS plugin rather than Mach itself, could be wrong though as I have only ever used Step/Dir spindle control.
« Reply #6 on: November 30, 2012, 04:08:57 PM »
I must have missed something I did not see mention of a SS.
« Reply #7 on: November 30, 2012, 04:15:55 PM »
Last line of second post.
« Reply #8 on: November 30, 2012, 04:20:55 PM »
YEP BLind as a bat on a foggy night.
(;-)TP
« Reply #9 on: November 30, 2012, 09:15:46 PM »
here is the file guys
