Hello Guest it is November 13, 2026, 05:01:20 PM
Author Topic: Buttons in pokeys plugin  (Read 12557 times)
« on: November 25, 2012, 10:40:03 AM »
Does anyone know what button number is used to bring up the mpg fly-out(tab key on keyboard)?
This is in the pokeys plugin.
Re: Buttons in pokeys plugin
« Reply #1 on: November 25, 2012, 12:27:18 PM »
You can do it by direct keymapping in Pokeys program.
« Reply #2 on: November 25, 2012, 12:42:08 PM »
I was successful in using the pokeys software, but I went back to using the Mach plugin to gain easier access to some of special function buttons.
It's funny that I can now get all of the buttons except for the easiest one. However I think that the tab is not a button in Mach. Mach is just reading the keys on the keyboard, i just need to find out how to map to the tab key function.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: November 25, 2012, 11:33:52 PM »
You can still use the 'tab' mapping from PoKeys configuration software as long as you leave it at 'Unused' function in Mach3 plugin.
