Hello Guest it is September 22, 2026, 11:20:34 AM
Author Topic: used encoder for feedback  (Read 11301 times)
« on: November 23, 2012, 12:50:03 AM »
I'm going to use the encoder for feedback on  x,y axes. So the encoder position of  axes appear directly to axes DRO.
What should I do?
Re: used encoder for feedback
« Reply #1 on: November 23, 2012, 01:59:33 AM »
If you are meaning axis DROs then you cant, if you are meaning encoder DROs then just put the encoders A and B channel to 2 spare inputs and configure them as the encoder inputs. Note that this will only be a visual thing as Mach will not act on encoder input.
« Reply #2 on: November 23, 2012, 05:00:40 AM »
I want to count axis DRO with encoder pulse and No with calculation.
for example ,
X Axis will continue to move until X position Encoder  reaches to the destination coordinates .
« Reply #3 on: November 26, 2012, 05:01:36 AM »
Who is accountable?
« Reply #4 on: November 26, 2012, 05:35:36 AM »
Who is accountable?
No one as far as you are concerned. You are using a pirate licence and you have the cheek to come here for help. I will not give you any and others have said the same in your other posts.
« Reply #5 on: November 26, 2012, 11:23:00 AM »
eelmans,
You were warned a few days ago via a personnel message. What words did you not understand?
I would apreciate that you understand  we don't condone or "support" illegal users.
