Hello Guest it is November 12, 2026, 03:42:32 AM
Author Topic: LED for in-position (servo active)  (Read 11086 times)
« on: November 19, 2012, 01:41:26 PM »
I am running mach 3 with 2 servos and Gechos
I need to have an external LED that turns on when the servo motor is in-Position (ACtive or what the proper title is.) Does any know of an circuit that would do this.
I talked to a Gechodrive engineer and he said there was no way to connect to the Gecho to do this.
I am not good at electronics and need help-
this is very important to my current project.
Jack Hoffa
jack.darlene.hoffa@roadrunner.com
714-990-5980
Offline comet
  •  338 338
Re: LED for in-position (servo active)
« Reply #1 on: November 19, 2012, 02:51:37 PM »
you could quite simplty tape a photo transistor over the gecko led and use it to trigger an imput to mach, same theory as an optoisolator.
  Tony
« Reply #2 on: November 19, 2012, 03:43:37 PM »
In position as compared to what ?
Even MACH3 does NOT know IF you are where you are suppose to be. It only knows it send signals out that if completed you will be where you should be.
The drive does not know where it is at it just processes pulses into moves.
Just a thought(;-) TP
« Reply #3 on: November 19, 2012, 04:51:14 PM »
I meant the servo is in-sink, or what ever the right name is, charged or alive?
Jack
« Reply #4 on: November 19, 2012, 05:02:01 PM »
Maybe you mean enabled and ready to move ? Tony had a pretty good idea there(;-)
