Hello Guest it is October 21, 2026, 04:21:18 AM
Author Topic: congreve clock  (Read 45187 times)
congreve clock
« on: November 19, 2012, 01:00:47 PM »
Hi all
Heres where I am up to.
Graham
  •  9,374 9,374
Re: congreve clock
« Reply #1 on: November 20, 2012, 04:14:46 AM »
Very nice workmanship Graham. That is certainly going to be a time piece to be proud of.
Re: congreve clock
« Reply #2 on: November 20, 2012, 06:41:11 AM »
Ditto!
What are you using to cut these beautiful works?
Re: congreve clock
« Reply #3 on: November 20, 2012, 11:28:01 AM »
Hi All
2 Axis Colchester Master Lathe which can be converted to a 4 axis cnc mill by swapping the toolpost with a vertical side and then adding a rotary table if required.
Drawn with autocad then coordinates used to manually create program.
All parts have been created this way.
Graham
Re: congreve clock
« Reply #4 on: December 21, 2014, 03:14:55 PM »
What will you use for the fusee chain and where will you get it?
Re: congreve clock
« Reply #5 on: December 23, 2014, 02:22:17 PM »
Hi Damianp
I used 1.6mm phosphor bronze multi stranded wire.
The nearest I can find now is 1.4mm from http://www.johnwardle.co.uk.
OR 1.5MM from http://www.clockmaking-brass.co.uk/miscellaneous_items%202.htmL
Best of luck.
Graham
« Last Edit: December 23, 2014, 02:36:01 PM by GRAYHIL »
Offline rdean
  •  94 94
Re: congreve clock
« Reply #6 on: December 23, 2014, 03:24:35 PM »
Very nice!
Excellent workmanship.
Ray
Re: congreve clock
« Reply #7 on: December 23, 2014, 05:36:40 PM »
Very nice! Way to go Graham!
Re: congreve clock
« Reply #8 on: December 23, 2014, 05:43:17 PM »
Been 2 years now.
Did you Git er dun Graham ?
Need pics !
Re: congreve clock
« Reply #9 on: December 24, 2014, 08:05:59 AM »
Hi All
See video
http://youtu.be/MnGHoMqAMzY
Graham
