Hello Guest it is November 13, 2026, 10:43:18 AM
Author Topic: Setting Multiple passes?  (Read 10110 times)
« on: November 15, 2012, 05:22:40 PM »
I"m engraving into aluminum and would like to know how to set up multiple passes to get deeper. I keep breaking bits if I try and do it all in one pass.
Can't find a setting for this anywhere and I tried to download the Mach3 manual from the Mach3 website but the english version is corrupt and won't let me download it
I have everything working good except I can't figure this out
Thanks in advance
Tim
Re: Setting Multiple passes?
« Reply #1 on: November 15, 2012, 05:36:02 PM »
Do it in your CAM program, or use the multipass wizard.
« Reply #2 on: November 15, 2012, 07:03:45 PM »
Ok thanks
I'm using Microcarve4 and It doesn't have that option as far as I can tell
What would be the most user friendly cam software that i should look into?
Mainly just engraving designs and lettering into aluminum pedal enclosures and want to start making pcb's
not sure how to use the multipass wizard, are there instructions?
