Hello Guest it is November 07, 2026, 07:20:28 PM
Author Topic: how to work the jcode recording plug in?  (Read 17479 times)
Offline v tec
  •  31 31
« on: November 14, 2012, 03:33:34 PM »
hi from france, someone can explain me how it work?
http://www.machsupport.com/plugins.php
because i need a plug in for recording a gcode, with the jog (motion for arm robot)7
thanks
  •  9,375 9,375
Re: how to work the jcode recording plug in?
« Reply #1 on: November 17, 2012, 07:34:02 AM »
Download the file, then run (double click) the saved ‘jcode.m3p’
Within Mach3:- Config / Config Plugins enable JCode
Restart Mach3
Title Bar :- select   Jog -> GCode / Record Jogs / select File / set Feedrate
Return focus to Mach screen and jog axis to required position
select Record Point
Repeat the above 2 operation as necessary (you may need a few hours to spare here  :) )
Then click OK to save the GCode.
This plugin has perhaps been superseded by the improved ‘Copy Cat’ wizard which is a lot easier to use but unfortunately requires the NFS Wizards licence.
« Reply #2 on: November 17, 2012, 07:52:38 AM »
You can also see a tutorial video here (click on the JCode link on the left):
http://www.machsupport.com/videos/
Offline v tec
  •  31 31
« Reply #3 on: November 17, 2012, 10:33:02 AM »
thanks very much, but i have a question
how we can do for record the 6 axis? (xyzabc)
because actually it record only xyz, it s a good start, but i need to record the 6 axis for my arm robot
« Reply #4 on: November 17, 2012, 10:39:46 AM »
I am afraid you will have to write your OWN application for that.
Offline v tec
  •  31 31
« Reply #5 on: November 17, 2012, 11:13:39 AM »
We cant modify this plug in?
I have never write or open a plug in
Offline v tec
  •  31 31
« Reply #6 on: November 17, 2012, 12:08:56 PM »
if i open the plug in with vs20XX, i can maybe modify something? i don t know how that work
