Hello
Guest
it is
November 13, 2026, 05:12:14 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
PoKeys
(Moderator:
NeoTO
Pokeys56 Pulse Engine and 4th Axis
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Pokeys56 Pulse Engine and 4th Axis (Read 12355 times)
g8kmh
3
on:
November 12, 2012, 04:48:41 PM »
If using the Pulse Engine for X, Y, Z, are there any recommended pins for step/dir for the A Axis?
Will an MPG drive the A axis via Mach3, bypassing the Pulse Engine on that axis?
Lehane
NeoTO
504
Re: Pokeys56 Pulse Engine and 4th Axis
Reply #1 on:
November 15, 2012, 03:39:03 AM »
Hi, Lehane
PoKeys supports only 3-axes at the moment and you can not assign additional pins for 'A' axis. The solution (pulse engine upgrade) is coming soon.
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
g8kmh
3
Reply #2 on:
November 15, 2012, 04:39:11 PM »
OK,
I'll look forward to that and leave the A axis until later. Let me know if you want an beta tester.
Lehane
Print
Pages:
1
Go Up
« previous
next »
