Hello Guest it is November 13, 2026, 05:00:08 PM
Author Topic: Pokeys56 Pulse Engine and 4th Axis  (Read 12353 times)
« on: November 12, 2012, 04:48:41 PM »
If using the Pulse Engine for X, Y, Z, are there any recommended pins for step/dir for the A Axis?
Will an MPG drive the A axis via Mach3, bypassing the Pulse Engine on that axis?
Lehane
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys56 Pulse Engine and 4th Axis
« Reply #1 on: November 15, 2012, 03:39:03 AM »
Hi, Lehane
PoKeys supports only 3-axes at the moment and you can not assign additional pins for 'A' axis. The solution (pulse engine upgrade) is coming soon.
« Reply #2 on: November 15, 2012, 04:39:11 PM »
OK,
I'll look forward to that and leave the A axis until later. Let me know if you want an beta tester.
Lehane
