Hello Guest it is November 13, 2026, 10:45:18 AM
Author Topic: softlimits and 4th axis  (Read 8053 times)
Offline tantan
  •  130 130
« on: November 04, 2012, 02:28:33 AM »
hi,
in general config there is an option to turn on/off softlimits for the fourth axis (rotational: rotational softlimits). this does not seem to work. if you turn softlimits on the softlimits for the fourth axis are enabled, no mather if the rotational limits are checked on or off.
tnx TanTan
Offline Fastest1
  •  920 920
  • Houston, TX
Re: softlimits and 4th axis
« Reply #1 on: November 10, 2012, 02:35:39 PM »
I was under the impression and I could be wrong, the rotational limits in regards to the dro resetting as it passes 360 degrees. Not sure about the soft limits aspect though wouldnt the actual soft limit for the particaular axis be in motor home and soft limits set up page?
