Hello Guest it is November 13, 2026, 09:50:17 AM
Author Topic: Adding buttons for Scripts  (Read 10779 times)
« on: November 03, 2012, 08:54:23 AM »
I've just added a laser cross hair to my router table.
The center of the cross image offset from the center of my spindle is -52.79mm in X and -0.375 in Y.
So I must add a Button and as assign a script to it.
Any guidance would be appreciated, I use the standard Mach3 screen and have not messed with it yet.
George
One step at a time!
Re: Adding buttons for Scripts
« Reply #1 on: November 03, 2012, 09:00:22 AM »
Do you need to know how to add a button? There are screen designer tutorials here. Screen 4, at the bottom of the list http://www.machsupport.com/videos/
Here's the code I use in my screen.
XOffset = -52.79   'X offset from laser crosshair to spindle
YOffset = -0.375   'Y offset from laser crosshair to spindle
SetOEMDRO(800,XOffset)
SetOEMDRO(801,YOffset)
Message "X and Y Axis Zeroed to Laser Crosshair"
« Reply #2 on: November 03, 2012, 09:29:02 AM »
Gerry, that looks good. I have watched the tutorial. Is Scree4 part of Mach3 or do I need to download it ?
Cant find it in my Mach3 directory.
George
One step at a time!
« Reply #3 on: November 03, 2012, 09:51:43 AM »
Thanks Gerry, I have downloaded Scree4 and will go lookie see.
George
One step at a time!
« Reply #4 on: November 03, 2012, 11:38:04 AM »
Thanks Gerry, all done now.
Works a treat.
George
One step at a time!
