Hello Guest it is November 08, 2026, 01:46:48 PM
Author Topic: MAch XML file location? Problem downloading MACH3 manual?  (Read 10588 times)
« on: October 30, 2012, 02:59:28 PM »
Can someone point me to the location of the xML profile for my machine.  It loads in the Mach loader but I do not know where the actual XML file is located.
Also I cannot seem to download the user guide or Mach3 manual.  My IE gives the message "file is damaged and cannot be repaired".  I tried restarting the pc and downloading it a second time and get the same message.
Bob
Re: MAch XML file location? Problem downloading MACH3 manual?
« Reply #1 on: October 30, 2012, 04:43:13 PM »
Your xml will be in your Mach3 folder.
Are you trying to open the manual in IE or are you selecting to save it?
« Reply #2 on: October 30, 2012, 07:21:54 PM »
Hi hood,
Thanks for the reply.  That is the folder I thought it should be in as well but could not find it there.  Found a folder named XML backups.
Sorry, yes I was trying to save the manual. It opened ok, at least the first time.
Bob
« Reply #3 on: October 31, 2012, 02:49:00 AM »
It will definitely be there, the backup folder contains backups of your zml that Mach automatically makes periodically.
It sounds like a browser problem, you should be able to save it fine.
