Mach Discussion => General Mach Discussion => Topic started by: bobmorey on October 30, 2012, 03:59:28 PM
Can someone point me to the location of the xML profile for my machine. It loads in the Mach loader but I do not know where the actual XML file is located.
Also I cannot seem to download the user guide or Mach3 manual. My IE gives the message "file is damaged and cannot be repaired". I tried restarting the pc and downloading it a second time and get the same message.
Bob
Your xml will be in your Mach3 folder.
Are you trying to open the manual in IE or are you selecting to save it?
Hi hood,
Thanks for the reply. That is the folder I thought it should be in as well but could not find it there. Found a folder named XML backups.
Sorry, yes I was trying to save the manual. It opened ok, at least the first time.
Bob
It will definitely be there, the backup folder contains backups of your zml that Mach automatically makes periodically.
It sounds like a browser problem, you should be able to save it fine.
