Hello Guest it is November 22, 2026, 10:12:22 AM
Author Topic: Input past end of File  (Read 9366 times)
« on: January 24, 2007, 08:40:48 AM »
I use Autocad to produce drawings which I then convert to dxf files for use on Mach3. When I try to load the file for conversion I often get an error of 'Input past end of File' which then prevents the dxf file from loading.
Any help would be most appreciated
Regards
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Input past end of File
« Reply #1 on: January 24, 2007, 12:36:14 PM »
try to output the file in an older format, maybe acad 2000.
Graham.
