Hello Guest it is November 12, 2026, 02:50:04 AM
Author Topic: G-code tool-path is much to large, Any ideas?  (Read 26553 times)
Re: G-code tool-path is much to large, Any ideas?
« Reply #10 on: October 27, 2012, 09:20:11 PM »
HUM something fishy.
Go to COnfig / native units / what is selected mm or inch?
Go to COnfig/motor tuning what is the Steps per setting on X axis(lower left side of window?
On the main screen to the right of the DROs is there a yellow led blinking ?
Main screen top right DO you see a G20 in the Modal line or a g21?
Offline B5
  •  13 13
« Reply #11 on: October 27, 2012, 09:27:55 PM »
MM is selected
Steps per in the motor tuning is 200
No LED flashing
And Yes there is a G20 in the #s  at the to right
Thanks for your help man, I really appreciate it:)
Offline B5
  •  13 13
« Reply #12 on: October 27, 2012, 09:49:24 PM »
Oh sorry, its a G21 not a G20 at the top right
« Reply #13 on: October 27, 2012, 10:02:01 PM »
WHen you commanded the machine to move 10mm and it moved 10.5" what did the DROs say it moved ?
« Reply #14 on: October 28, 2012, 07:53:19 PM »
HAve you found the problem yet?
Offline B5
  •  13 13
« Reply #15 on: October 28, 2012, 10:21:51 PM »
Something must have reset when I tuned my computer off.  Your code does now move the machine 10MM:)  But my tool-path is still massive.  Is there anything else it could be?
Offline B5
  •  13 13
« Reply #16 on: October 28, 2012, 10:59:21 PM »
Do you think its the Code?  I have a mach3 MM post-processor so it seems like the code should be right.  Ive run the code offline and everything seems great, It's just way bigger than its supposed to be.
Offline B5
  •  13 13
« Reply #17 on: October 28, 2012, 11:22:27 PM »
Yeeeeeehaaaa!! Awesome, it just dawned on me that I forgot to redo my limits after I calibrated, now all is good.  The code wasn't to big, the table was to small.  I'm a total dunce.  Thanks for your help though man.
« Reply #18 on: November 01, 2012, 07:42:49 AM »
Glad you got it figured out
