Hello Guest it is November 12, 2026, 02:49:55 AM
Author Topic: G-code tool-path is much to large, Any ideas?  (Read 26550 times)
Offline B5
  •  13 13
« on: October 27, 2012, 03:36:11 PM »
Hi there, I'm new to all of this but I just got a Zen Toolworks 12"x12" CNC machine.  In Mach3 I've set up all the ports and pins, set soft and hard limits and calibrated the machine.  All is running well however when I import my G-code my design, instead of being 80MM x 80MM or so, it's huge, its probably 2.5 x 2.5 feet.  I am using artCAM to build the code and have a Post processor for millimetres.  Any ideas as to whats going on?
Re: G-code tool-path is much to large, Any ideas?
« Reply #1 on: October 27, 2012, 03:55:43 PM »
IS your machine setup in MMs ?  Is there a G21 at the start of the Gcode to tell it to use MM ?
IF you command a move of say 80mm does it move exactly 80mm?
Can you post the file so we can look at it.
Offline B5
  •  13 13
« Reply #2 on: October 27, 2012, 04:19:27 PM »
Here it is, the G-code is attached as a PDF, I guess the forum cant upload a .cnc file.  There is no G21 at the beginning although I tried to put it after the % and regenerated the toolpath but no luck.  Where do I put the G21?  And yes I set up Mach3 for millimetres and under the settings tab it is set on MM.
Thanks for your quick reply
Here's the beginning
G91.1
M5 M9
M6 T1
G43 H1
M3 S15000
G0 X40.058 Y58.559 Z5.000
G1   Z-2.000 F720
G1 X85.555 Y58.564  F1200
G0   Z5.000
G0 X85.557 Y58.559
G1   Z-2.000 F720
G1 X62.808 Y97.968  F1200
X40.061 Y58.559...............)
« Reply #3 on: October 27, 2012, 05:54:33 PM »
IF your machine is in MM and the CAM created MM code as it appears then that is not the problem BUT it should have put a G21 at the start to insure it is in Metric mode.
NOW if you command a move from the MDI line say G1 X10 F100. Does it move exactly 10mm?
G91.1 G21
M5 M9
M6 T1
G43 H1
M3 S15000
G1   Z-2.000 F720
G0   Z5.000
G0 X85.557 Y58.559
G1   Z-2.000 F720
X40.061 Y58.559
Offline B5
  •  13 13
« Reply #4 on: October 27, 2012, 07:43:12 PM »
I put in the code but like you said it didn't change anything.  I put that G-code into the MDI though and my machine went 10.5 inches!!!!!  So something is definitely wrong there.
« Reply #5 on: October 27, 2012, 07:51:56 PM »
YOUR motor tuning settings are off on  Steps per MM. Either recalculate them or use the calibrate utility it get it right.
Offline B5
  •  13 13
« Reply #6 on: October 27, 2012, 08:06:35 PM »
Cool, I'll try re-calibrating and let you know
Offline B5
  •  13 13
« Reply #7 on: October 27, 2012, 08:20:20 PM »
So tried re-calibrating and nothing changed.  It asked how far I want it to move, I put 5 which I assume would be MM, and it moved 5MM so I put that in when it asked me how far it traveled.  Then it said that it would change it to 200 (steps a minute I think) and I said OK.
Am I doing that wrong?
« Reply #8 on: October 27, 2012, 08:25:34 PM »
Sounds right. NOW does it move the correct distance when commanded ?   does G1X10 F100 = 10mm movement ?
Offline B5
  •  13 13
« Reply #9 on: October 27, 2012, 08:59:52 PM »
No, still 10.5 inches.
