Hello Guest it is November 13, 2026, 01:12:08 PM
Author Topic: Plasma Consumable Tracking  (Read 168006 times)
Re: Plasma Consumable Tracking
« Reply #90 on: November 02, 2012, 01:32:03 PM »
In Scam like mach3 and other developing software there are always the posibilities of a bug sneaking in. IF you check on the Scam Yahoo site I am sure if there is a problem it will be mentioned AND fixed right away. IF not then please bring it to Les's attention .
O master ??? you must have me confused with someone else I am a HEY YOU.
« Reply #91 on: November 02, 2012, 04:15:59 PM »
IS it tuesday yet?
Do you have need for a basic shapes generator for plasma ?  It generates gcode for basic shapes like squares,rectangles, Circles,ovals,triangles, Burn holes.
It is in PAGE form you would add the page to your existing screenset.
« Reply #92 on: November 02, 2012, 04:47:52 PM »
 ;D SURE Lay it on me TP. I a gluten for punishment.LOL
GL
« Reply #93 on: November 02, 2012, 05:13:47 PM »
Here it is 2 different ways the file will unzip to 2 page file sets. Same page just different ways for Machscreen to use.
« Reply #94 on: November 02, 2012, 05:17:36 PM »
Thank You, Thank You!  I'll my best to do you proud. lol
GL
« Reply #95 on: November 02, 2012, 07:19:16 PM »
Never mind, I figured it out. Had a brain fart. LOL
GL
« Last Edit: November 02, 2012, 07:21:31 PM by scbrniddvl »
« Reply #96 on: November 02, 2012, 07:25:12 PM »
Ok, I do have a problem. I un-zipped the two files and tried to open them in Machscreen and all I get is a grey box.  ???
GL
« Reply #97 on: November 02, 2012, 07:35:02 PM »
 ;D Never mind, got something now.
GL
« Reply #98 on: November 03, 2012, 09:31:37 PM »
Ok TP, I got Shapes running. Had to mess with the screen quite a bit, but works good. I used the PlasmaShapesWizard 2.zip files. I LIKE IT. I cut a lot of just simple brackets, gussets and plates and this saves so much time. No drawing to do, no posting it's great. Love it!!!
Thanks a bunch
GL
« Reply #99 on: November 03, 2012, 10:00:20 PM »
You are DA MAN, (;-)
What else do you need ?
InSheetCam we have the Barcoding of the Filename to the report section working GOOD. When you post your part file you also create a report to print. When you are ready to cut  that file we use a barcode reader to read the filename into MACH3.
Not really for everyone but it saves time and typing or MISTYPING here (;-).
How about a quicky FILE reader PAGE for mach3. You can load and veiw files then decide to keep or MOVE or delete the file from the mach3 Gcode dir.
