Hello Guest it is October 02, 2026, 06:08:19 PM
Author Topic: Jog It! Open source CNC pendant project  (Read 84424 times)
« on: October 26, 2012, 10:38:15 AM »
Hey everyone!  Some of you may have already seen this on the web, but for those that have not, this post is for you!
I have developed an Open source hand held pendant controller that lets you jog, home your machine, and start running a program all from the pendant, without using your keyboard or mouse (once you have your G-code file loaded)
I have launched a Kickstarter to sell the first batch of them, check it out!  Grab one if you like it. (kit version or complete model, its up to you!)
See it here! http://kck.st/RITAPy
Grab one before the 22 days I have left are up!  After the Kickstarter ends and I sell these on the web, the price will be higher.
Also, For custom load screen creators.  If you have created a custom load screen that is available here for sale or download on the Mach3 site, I will send you a free Jog it! cnc pendant in exchange for a custom load screen that makes the pendant work with your version. (there are just a few custom keyboard shortcuts that need to be added)
Re: Jog It! Open source CNC pendant project
« Reply #1 on: January 14, 2013, 10:36:57 PM »
...been using my jogit pendant for a few days now...bummer though I'm stuck using a non preferred screenset at the moment as some of the button function only work with a version of the stock screen sset.
I'd LOVE to get the minor additions done to that screen set so I could add them to any other prefered screenset.
thanks.
« Reply #2 on: January 15, 2013, 11:24:28 AM »
Perhaps you might want to LIST all the parameters that needed to be present on a screenset to make your pendant compatible.
« Reply #3 on: January 15, 2013, 12:36:40 PM »
thanks.
Can't you just open up the screenset that has the functions you need, and copy those over to the preferred screen set you'd rather use?
« Reply #4 on: January 15, 2013, 04:26:09 PM »
thanks.
The code does not look like a usual set file........
https://www.dropbox.com/s/0bam6oqrpat9u81/jogit.set
« Last Edit: January 15, 2013, 04:30:31 PM by ptegler »
« Reply #5 on: January 26, 2020, 10:47:39 PM »
Are these jog pads still available ?
