Hello Guest it is November 13, 2026, 12:20:08 PM
Author Topic: Help...! No Driver Sensed - Run Driver Test - ERROR  (Read 12889 times)
Dansway
« on: January 23, 2007, 04:23:00 PM »
I'm running Win XP Prof on a laptop (Toshiba Satellite)
I uninstalled Mach3 ver 1.8 and tried to install 2.0+ and at the end of the new installation, Mach3 gave me the error of "no driver sensed" etc.
I've looked high and low for the Mach3 driver in device manager and it is not showing up.
Please help!!!!  How do I get past this problem so I can use ver 2.0....?
« Last Edit: January 23, 2007, 05:39:46 PM by Dansway »
Re: Help...! No Driver Sensed - Run Driver Test - ERROR
« Reply #1 on: January 23, 2007, 07:44:57 PM »
Try downloading again after you uninstall the first attemp. When Mach is loading it ask if you want to install drivers. Make sure the box is checked and install the drivers. Let us know how it does.
Dansway
« Reply #2 on: January 23, 2007, 07:52:13 PM »
Art emailed me this response earlier today:
Hi Dan:
Running the DriverTest.exe will reinstall the driver by itself. If it wont install, it points to either not being in admin mode, or a corruption of the XP install facility (Which Ive seen before. ). Reinstalling Windows on top of itself fixes that one if the drivertest.exe and logging in as Admin wont..
Art
www.artofcnc.ca
« Reply #3 on: January 23, 2007, 07:55:25 PM »
Well, you know, he is the man.  ;D  Let us know how it works out.
